Coolant leak... Fix neede ASAP.
    Ok, so car starts leaking coolant all of a sudden, I can see the water drip, but not the actual leak itself. I'm sure theres at least a couple of you guys here that know whats wrong. Here's a shitty cell phone pic. Need help ASAP, thanks.
    Shitty pic. It looks like its coming from that hose. Drain coolant, remove and inspect hose, replace hose, put in new coolant. If hose looks fine, check other hoses.
    You really need to find out where exactly its leaking from, all that pic tells me is its leaking from somewhere.
      Was hoping to not have to get underneath, but I guess that's unavoidable... All I can tell it that the whole area is wet around that bolt (the bright one in the pic.) The ring on the hose is also wet. If it helps, it sprayed all over the engine too...
        water pump maybe? thats what happend in my 525i not fun
        www.gutenparts.com
          Well, I'm just going to replace the timing belt while I'm at it... Looks like I'll have to take all the hoses and shit off anyway. It's leaking about a gallon every 10 minutes.
