no brake lights
  • Schnell 318
    • 567
    no brake lights
    my brake lights have stopped working. the rear turn signals still work and the taillights come on with my headlights, but when i press the brakes the lights dont come on. i check the fuse box and nothing is blown. what could the problem be? is there some kind of sensor under the brake pedal that could be broken?
  • rs4pro3
    • 5808
    switch on the break pedal, either broken or misadjusted. I had to rubber band a small piece of cardboard to both my break and clutch pedal to get them to engage the switch.
    85 325e 2.7 ITB'd stroker
    • Beej '86 325es
      • 2639
      Remove the panel above your knees and check the switch located in front of / above the brake pedal. The switch is like a button that is held out by a spring. If it is not springy feeling, then the switch is certainly broken. Otherwise, you might try unplugging it and putting a jumper wire between the contacts to bypass the switch and see if they light up then.
      -Brandon
      '86 325es S50
      '12 VW GTI Autobahn DSG
      '03 540i M-Sport (sold)
      '08 Jeep SRT-8 (sold)
      For sale:
      S50 TMS chip for Schricks
      • Schnell 318
        • 567
        yeah it was the sensor
        thanks guys
