Oil problem on check panel
  • andrewintraining
    • Jan 2008
    • 78
    I had my oil changed about a month ago and probably havent put 1000 miles on it yet. And my OIL light keeps coming on, I checked the oil levels and theyre good...
    I heard there is a way to reset the oil sensor.
    Looking for an e30.....
  • Sean
    • 5793
    Is ti the oil pressure light(red light on dash) or the countdown light things, so it flashes red in the middle, where the green lights are?
    - Sean Hayes
    • andrewintraining
      • Jan 2008
      • 78
      No the it just says "Check - Engine Oil" on the check panel......
      • One21Two
        • Aug 2007
        • 711
        I have the same thing in my car intermittently. From wut I have researched its the "Oil Pressure Sensor" located right under the oil filter canister. I bought one from BMA for $5 and I'm going to try to oil change my car today and replace the sensor. Hopefully thats the issue. I'll let you know wut happens. Too bad its raining. Might not get a chance to do it today.
        • emi325i
          • Oct 2006
          • 356
          The check panel warning light is for the oil level. the warning light in the dash is for oil pressure. sounds like your oil level sensor is bad. that's located in the top part of the oil pan.. driver side.
          • NC325iC
            • Mar 2004
            • 6565
            ^ just fill er up and you should be fine
