Cruise no longer works after doing dash swap?
  • Spencer
    • 767
    Any idea?
    What did I forget to plug in?
    It’s not the fuse.
    Spencer
  • James Crivellone
    Head Janitor
    • 6304
    Blue connector above the ECU, make sure its plugged into the Cruise Computer
    Check round connector that is above the brake pedal, that goes up to the servor, check and make sure the clutch disable switch connector is plugged in and functioning. Also check the single wire that runs up to the back of the speedometer (the one that plugs into the row of green plugs on the back of the cluster)
    make sure your brake warning light is not on.
    stuff like that
    • Giorgio
      • 169
      I just did my OBC and found out that the cable plugged into the instrument cluster was unplugged, maybe try that.
      • Spencer
        • 767
        "make sure your brake warning light is not on."
        You mean the break lining light? Cause that light is on.
        Spencer
        • James Crivellone
          Head Janitor
          • 6304
          Spencer
          no, the brake light indicator on the check computer
          • Beej '86 325es
            • 2639
            Spencer
            That won't affect anything. My little brake light warning was on for years and I used my Cruise all the time.
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • Spencer
              • 767
              The brake indicator IS on in the check panel. What does this mean?
              Spencer
              • James Crivellone
                Head Janitor
                • 6304
                Spencer
                It did it on my blue car, but not on my white one,
                may be a revision change or something
                • James Crivellone
                  Head Janitor
                  • 6304
                  Spencer
                  one of your brake lights is out. lol
