no heat??
    Originally posted by jw 325ic View Post
    wouldn't that mean that the heat would always be on? As in even with it on cold, it would only have heat coming out?
    yeah, something like that. I drilled mine out a couple of year ago. It sucked ass, basically, in summer. I am glad mine is fixed now!
    Closing SOON!
    Thanks for 10 years of fun!
      It's still controllable by the knob, you can still set it to "blue" and block off airflow through the heater core, BUT the reason that valve is in there, is with hot coolant flowing in the dash and around your legs from those metal tubes through the firewall, its gonna bring some heat into the cabin constantly. You will have a LOT of heat though when you crank the knob.
      I've seen that "fix" made permanent on a few cars where they just add a manual shutoff under the hood.
      For a temporary its-friggin-cold-out fix, knocking out the valve works well if you can get another one easily at the junkyard to replace it with
      . If this is not the case, Look at what that sucker costs before you do anything to it..... It's not cheap IIRC
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
        $120ish?
        Closing SOON!
          He said he popped a fuse though, might have been the bitch fuse
          Closing SOON!
            $120 isnt that bad, must have thought about something else. That or im still bitter over the price of a heater core.
            -Dave
              hmmm ill just wait for the next junkyard trip. springs almost here in dallas, so that means windows down. if i take the valve out, ill be replacing it. i guess at that time ill do the fuse too. thanks for all the help guys.
