Various things; please read, you
  • jerods87e30
    • Jun 2007
    • 226
    Had a few Q's on my E30:
    Has anyone ever had their blower motor squeak and squeal high-pitched before at random? What'd you do 'bout that...
    My brights sometimes randomly flash on and other cars get real pissy. To replace the turn signal/dimmer stalk, do you have to wire things up or is it a plug or something?
    Has anyone ever removed (from an E30) the hood pop cable and pull lever? How do you do it, and, where the fuck do you start? Mine broke right at where it fastens to the handle. ...and how do you remove the latch itself?
    What's the max. CCA you can have with a battery for an E30?
    Does anyone (literally, any person) have a pearlbeige, vinyl sport seat from an 87 E30? god damn.
    Thanks E30'ers,
    -J
  • jerods87e30
    • Jun 2007
    • 226
    anybody?
    • StereoInstaller1
      GAS
      • 22679
      Shit, I wrote a big post about how to change the hood pop and must have not posted it!
      Pull the left grille, 2X10mm bolts gets the hood latch out. Pull the underdash hush panel, 2X8mm bolts gets the handle out: cable is gonna be a bit of a bitch, but only a single grommet holds it in.
      CCA? Why, big stereo? I will be using 2X redtops on mine. Michigan does get cold, so I would go big if you plan on driving in the winter. Optimas have a lower ESR, so you can go bigger than normal if needed.
      Random squeal, random flash, NFC here, sorry.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • DaveSmed
        • Apr 2007
        • 1407
        The random squeal is your 20 year old blower motor showing its age. It's probably gonna kick it some time soon.
        There is a plug for the stalk, its further down the column.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
        • mrsleeve
          • Mar 2005
          • 16387
          I can hook you up with a good upholster in Dexter MI that redid mine for cheap an did a great job. PM me an I will get you his contact.
          Originally posted by Fusion
          William Pitt-
          • Mr.sexymorningvoice
            • Sep 2007
            • 402
            Thanks E30'ers,
            -J
            btw there really is no battery that has too many cca's, i would say just get the biggest battery you can fit in your battery tray. The more cca's, means less stress put on your starter
            • jerods87e30
              • Jun 2007
              • 226
              Luke
              Yeah, I figured the hard part would be the damn cable itself. You say one grommet? Where, firewall?
              thanks everyone,
              -Jerod
