When I turn...
  • Werksmini
    • 1658
    When I turn...
    There is a funny noise that comes from the drivers side of the engine compartment, its really hard to describe though. It only happens when I turn the wheel, its kind of like a wooshing, but not like something is leaking. Also there is a rubbing sound, that may be because of the "rail" that powers the horn in the stearing wheel, but im not sure about that either. Any experience?
    I bombed Korea every night.
  • Erick
    Official R3V Drifter
    • 11169
    I had a rubbing sound coming from my steering wheel.... it got worse and worse. I popped the hood and spun the wheel..... my pressure hose was leaking.....
    The car is down now awaiting a new hose that should get here hopefully Tuesday.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • chrisd
      • 288
      power steering noises
      the power steering pump is on the driver's side of the engine compartment.
      It is only active when you turn... it's a likely candidate.
      I just had my power steeing belt cut through the coolant hose, so I cut it out. I like driving the car better without anyway...
      • UNHCLL
        • 8790
        check to make sure you have enough fluid in there.
        If you dont, it will make a whine/whoosh.
        The power steering fluid... check that.
        Below the radar...
