I tossed my old heater & a/c housing last year and got one from a newer car (I don't know what car it's originally from). Why, well not having a defroster was not a good idea, plus my rear defroster also doesn't work since the switch plugs into this mess. Wiring ended up being different, of course. There is a yellow sticker on the plastic box with "2/11/88/24", makes me think it's from an 1988 car, is that right ?
The main wiring plug is white and rectangular with a white tag on it with a "1386518.0 E 4224.7 90 928 18 899" printed .
The female end of this plug under my dash is not the same style / shape.
I am just trying to figure out if I can swap the wiring to the right one instead of splicing it...so I've been trying to find the right wiring set part number to do this swap... the defroster switch and the fan speed switch I got from a newer car so that's not a problem.
Does anybody know if pn 61121381797 (from 9/84) is the wiring set that goes on the heater and a/c housing and connects to the relays and all the junk on it , there must be different part numbers for different years though ?
When I select an early 318i it shows pn 61121381797 Up To 9/84.
http://www.realoem.com/bmw/showparts...22&hg=64&fg=35
The same exact part number comes up when I select an 88 car, pn # 61121381797 but says From 9/84.
Also, I do not remember having these connectors on my old housing that I tossed away.
This?
And this?
Is this some kind of temp. sensor ?
This?
And this?
