cleaning m42 ICV
  • jrobie79
    • Mar 2006
    • 2526
    cleaning m42 ICV
    how do you clean the ICV, i sprayed TB cleaner in it, but is there a way to get to the inside, also i noticed the black cap near the electrical receptacle was loose so i popped it off and saw that one of the two little probes there was lose, it was still connected to a wire going to the inside of it, but the piece the wire was attached to was loose. is this a problem?
    1991 318i ---- 308K - retired
  • hamann318is
    • 3382
    The way I've done it was just to spray some cleaner in there and let it dry out for a bit. I wipe what I can with a paper towel, and let the cleaner soak and dry.
    The BMW 318 is back. With a vengeance.
