My car weight.. amazing
    Well I decided to weigh the project car today.. i'm pretty impressed (i've just copied and pasted this post of my home forum so ignore the locations and stuff - wanted to see how this stacked up to some american cars.
    The weight was taken with:
    A full tank of gas approx 50 kg of fuel
    and my car runs.. 2 very light Jamex seats.. no rear seats.. no sound deadning under back seats and no sound deadning in boot and WITH the spare wheel.
    A grand total of 1070 kg 2354 lbs done at the north shore city dump.
    Not bad aye..
    btw the car is a 2 door 1984 323i manul coupe.. it now has:
    A motronic fully rebuilt 325 motor with pre-motronic 323 head
    Lightened crank, flywheel, con rods + all fully balanced
    323 head rebuilt (slightly smaller ports so more torque) that had the combustion chamber machine to stop the pistons hitting the head - resulting in a pretty high compression ratio.
    Jamex 40mm prog springs wth Bilstein sport shocks + full urethane bushes
    Custom 2.25 inch exhaust
    Tommorow on the dyno we'll try for 100 rwkW and 240 rwNm torque but i'm not that hopeful .. i'm running RON 96 and its noticeable how motronic caps the performance to reduce knock.. i'll dyno it with 98 also next week.
    I bought the car with the motor swap but the first day I got it, it dropped an exhaust valve completely destroying the head and piston #6.. so I went all out and did the full rebuilt - it is very hard to find the 2.7 crank in NZ so I couldn't go down that route.
    Gasoline weighs 6.02 lbs per gallon so small tank would weigh 37.5 KG.
    1070Kg = 2359.35 lbs nice and light.
      not bad for a 325 i guess..
      also no A/C fitted from factory and manual rack is in.
        is it an 323i ?
        early E30s are lighter (pre 85)
        1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
        1997 E36 328iT
        1990 E30 325iT 24v SOLD
        1989 E30 325i 2.7i M-Technic II SOLD
          Originally posted by BavarianBimmer
          is it an 323i ?
          well I guess technically it is.. but it has the 325 motor in it that i described above.
            Wow, my 318i was 2360lbs with full interior/spare/1/8th tank of gas. Impressive numbers.
            What do you mean Motronic caps performance to reduce knock? No M20 ever had knock sensors, Motronic shouldn't change anything if your engine is detonating.
              DAMNIT bill you beat me to it!
                I was under the impression it could retard the timing.. i'm sure it retards the timing when your cruising at like 60kph in 4th gear - my L-Jet car starts pinking like a bitch. Any how - can't wait to ditch the motronic in favour of Link engine management early next year - turbo time.
                  it probably does pull the timing a bit under cruise conditions, but because it switches to another ignition map because one of the variables that the ECU sees told it it was cruising..but one of those variables isnt a knock sensor...Moronic is stupid!
                    wow, that is light for a six-banger... i have a new goal to aspire to, i was just gonna go for 2600 wet :P
                    past:
                    1989 325is (learner shitbox)
                    1986 325e (turbo dorito)
                    1991 318ic (5-lug ITB)
                    1985 323i baur
                    current:
                      Ahh i understand.. it pretends to be smart.
                      Are you still running it with your turbo?
