Question on valve cover
  • -Javier-
    • May 2007
    • 382
    does the valve cover has a gasket ?
  • Jand3rson
    • 37587
    Yep. They're only like $9. If you're going to be pulling your cover, get a new gasket.
    • -Javier-
      • May 2007
      • 382
      i should change mine, i dont know when was the last time it was done.
      • Mike325
        • Mar 2006
        • 3685
        Should adjust the valves while you are in there.
        Originally posted by Kershaw
        • -Javier-
          • May 2007
          • 382
          done that
            In addition to the gasket there are four rubber bungs (two at each end of the head) that should be replaced also.
