Weird blower/rpm/dash problem.
    On key at ACC.
    No Blower fan, no gas gauge.
    Start the car.
    Blower works for 2 seconds, then it cuts off along with the rpm, gas gauge and coolant temp.
    Check all fuses, but the fact that it works for 2 seconds leads me to believe it aint a fuse.
    When driven the speedometer works, rpm and everything else dead.
    Werid fucking problem, I have no idea why it effects my blower fan.
    Could it be si batteries?
    I suspect two coincidental problems since those are different circuits. The cluster faults might be a bad SI board or other problem withing the cluster. The blower issue might be in the switch, resistor, motor, or power connections.
      Fuck me, Fuse 10 was blown.
      Have no idea why that would effect the blower fan, since it was on fuse 20 and that was the fuse i was checking.....along with a few others.
      damn 7.5A brown fuses, the thin wire is hard to see when broken.
      Thanks jlevie: fuse 10 fixed all problems, which fucking puzzels me.
