weird wiper issue
  • dlmrun2002
    • Apr 2007
    • 808
    weird wiper issue
    Wipers seem a bit slow. Pass side seems to have a mili-second lag. They also don't really rest at the bottom...most of the time at least. They have play to be pulled down to sit right at bottom of windshiled when turned off. Arms were put back on the right spot too..Transmission wear?
    DLM
  • hayes3054
    • Nov 2007
    • 26
    Knuckle buster
    I had that problem about a year ago. Nut that holds the linkage to the motor was loose. With wipers in the park position, loosen nut on motor shaft, move wipers to normal position and tighten the nut.
    individualistView Public ProfileSend a private message to individualistFind More Posts by individualist
    11-03-2007, 04:24 PM #4 hayes3054
    E30: 1987 325 Posts: 17
    Thanks I'll give it a try. I already took the motor apart. Big mistake. It's very tough to get back together. The square nuts won't stay in place while I'm screwing it together. I also tried moving the arms which resulted in them going too far down.
    How do I get to the nut the connects the linkage to the motor. Bloody nuckles I guess.:???:
    Thanks
    hayes3054View Public ProfileSend a private message to hayes3054Find More Posts by hayes3054
    11-04-2007, 07:50 AM #5 hayes3054
    Problem Solved
    Thanks guys. Just like he said. There is a 10mm nut on the bottom of the motor that holds the linkage on. Just remove, pop the arm and reset.
    Much better.:grin:
    • hayes3054
      • Nov 2007
      • 26
      As far as the slow wipers go, mine got alot faster when I replaced the alternator.
