No 4way flashers......
    So i bought the car without workign 4way flashers. I figured it was the switch since it didnt look like it was in very good shape, but the brand new one i purchased didnt fix the problem. So what else could be causing my 4way flashers not to work when i press the button?
    Dave
    E30 Dinan Turbo
    jeez... only 11 views... i should have titled this "a 4way"
    E30 Dinan Turbo
      what do you mean 4 way flashers?
        I mean the flashing park lights when you press the hazard switch.
        Dave
        E30 Dinan Turbo
          My wiring diagrams & such are still in the track trailer from this weekend, but seems to me there's a flasher relay that could be bad. Check http://wedophones.com/BMWManualsLead.htm for the ETM for your car.
            Thanks for the help. There is infact a flasher relay. Looks like that will be the next part i will be ordering. Anyone with any ideas as to where this relay is located in the car?
            Dave
            E30 Dinan Turbo
              Could be a fuse as well I had like 3 gone when I bought my car and they didn't work. Changed the fuses and it worked right away. I think they relay shoud be in the fusebox, and if not it might be on the firewall with the fuel pump relay or something.
                Alright i'll look into it... thanks for the info guys. I'll keep you posted...
                Dave
                E30 Dinan Turbo
                  Well even though i went over all of the fuses and replaced the ones that needed replacing when i first bought the car... i most certainly missed this one.
                  Problem fixed.
                  Thanks all.
                  E30 Dinan Turbo
