We removed the hood and cannot seem to get it back on so works like it did when we removed it. It lines up and closes just fine. When we pop the latch it doesn't roll forward the way it used to. Any thoughts on what we missed? The Bently manual isn't much help.
Hood install question
"Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!"Tags: None -
you didnt hook the "springs" up correctly on the brackets
Make sure they are in the hole in that outside bracketsigpicComment
Part number 16 is the Bracket im referring to.
http://www.realoem.com/bmw/showparts...=41&fg=35&hl=2sigpicComment
There are two sides to the springs
I think the "L" or bent side looks pretty obvious where it goes, we have it in the slot. I wonder if we have the other end of the spring in the wrong spot?sigpic
"Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!"Comment
