Evaporator Temp Regulator
  • kroberts
    • 680
    Is this little gem an integral part of the evaporator or is it a separate little box somewhere? I'm trying to troubleshoot my AC clutch wire.
    Thanks,
    kr
  • rs4pro3
    • 5808
    It's a small box mounted on the side of the HVAC unit. It's close to where the heater core valve is on the driver's side under the dash
    85 325e 2.7 ITB'd stroker
    • kroberts
      • 680
      Thanks, looks like a big relay or flasher. I think mine just shit the bed.
      • kroberts
        • 680
        HOLY SHIT! That little frigging part is $103...I'll try the junkyard first.
        • rs4pro3
          • 5808
          I've got 3 or 4 used ones laying around here. Send me a pic or part # of yours so I can find one that matches(there are 2 different ones that I know of)
          • kroberts
            • 680
            • rs4pro3
              • 5808
              yep I have one how about $15 shipped
              • kroberts
                • 680
                Never mind, I figured out what my mistake was. My regulator is fine. I had to jump the connectors at the coolant temp switch plug. The S14 would shut off the A/C if the coolant temp rose above 226 degrees F.
                Those troubleshooting charts work great if you take the time to read them correctly.
                Thanks anywho
                kr
                • rs4pro3
                  • 5808
                  no prob.
