Thermostat bad??
  • sparticus
    • Jun 2004
    • 64
    Thermostat bad??
    Other than a higher water temp how else can you tell if you need to replace the Thermostat?? I flushed Rad and temp goes to 3/4 still???
  • ///M42 sport
    • 3952
    Its basically process of elimination. Fan clutch, thermostat, radiator. You'll have to replace each on and see what happens.
    ________
    Voyeur amateur
    • sparticus
      • Jun 2004
      • 64
      I've done the newspaper test on the fan and it doesn't stop abrubtly(?) but slows down gradually if the rolled paper is left in the fans path. Is it still good ??
