drain hole location for cabs
  • ///M42 sport
    • 3952
    I cleaned mine out recently and thought I would post pics of where the drains are for the top cover.
    My carpet was always wet in the back when it rained. Hopefully this prevents that from happening again. BTW when you test the drain, you should see water drip about 2 feet in front of the back tires.
  • -Javier-
    • May 2007
    • 382
    HOLY crap dude, my car does the samething when it rain i always get the rear carpet wet, and i didnt know there was a drain hole there.
    • -Javier-
      • May 2007
      • 382
      I was checking that spot today and I free them from dirt that was there, but I still don't understand how water gets in the rear carpet?
      • ///M42 sport
        • 3952
        that is the most likely spot. or it could be the window seals. Is water draining out when you test them?
        • -Javier-
          • May 2007
          • 382
          Yep just like you said 2ft on the front rear tire on both sides
