Rear shock mount parts and procedu??
  • Gene in NC
    • Oct 2005
    • 11
    '87 325is w 300k+; rubber in rear shock mount has failed. REALOEM shows rubber as a separate part. Is the part available (#9 on the parts explosion) and can it be replaced from inside the trunk?
    Yes, you're right, shocks should be replaced and will be later.
  • lordofthewaters
    • Oct 2005
    • 714
    Easy to replace two nuts to remove from inside the trunk.
    I recommend going with the cab mounts. They're heavier duty, and will last longer.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • Dave
      E30 RAT
      • 11675
      Gene, I think you might find more info if you search around.
      If you are wanting to stay with a stock type ride, Meyle makes an improved rear shock mount with a tapered core that should last longer than the stock ones. As noted above, the e46 Cabrio rear shock mounts are another OE style upgrade.
      If you go with one of these - make sure you get everything installed correctly. I know there is a thread around here that goes over that.
      Another option are the "repair shop" mounts that Bimmerworld sells.
      If you want something stiffer, look at the urethane mounts from Bimmerworld or Ireland Engineering.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
