I was planning to run my turn signals so that they only lit up when I was actually signaling.
I removed the small plug on the right side for it, and it worked fine. Signals, but is off otherwise.
Went to the driver side, and looked for the plug. Unplugged something accidentaly, and now the low beams don't work at all! I replaced the fuses, and that didn't help. What should I do? Wiring problems are the hardest to figure. Also, the plug I removed from the right side was not even there on the left!
Help!
Help!
