More issues with 325es
  • willsol
    • May 2007
    • 334
    Ok last night tried to start the car and this is what happened.
    Here is the issues...
    My starter locked up and and we had to push start it....
    Then one the way back no matter what gear I had it in if I pushed half throttle it was fine.. full throttle it just wouldnt go any where just bogged down.
    Also idled really low too...
    So yeah bunch of stuff to check out now.
    Any advice on stuff to check out for the bogging down would be appreciated.
    btw- recently changed the rad fluid and brake fluid.
  • jw 325ic
    • Sep 2006
    • 1360
    for the idle and the throttle id check your injectors if you havent already. even the spark plugs. also check your icv. unless you didnt bleed the brakes and thermo, that would have nothing to do with anything. brakes would have a reaction to the braking, coolant would have a reaction as in overheating.
    • willsol
      • May 2007
      • 334
      thats what I thought about the braking and cooling... its crazy that it just happened right after doing that stuff though.
