Took our rear seat, strange noises!
  • E30godz
    • 1524
    Besides being able to hear the fuel pump a shit load more, i also notice a really bad clunking sound with shifting now so smoothly or jabbing the gas from a no-throttle position.
    what could it be? Something tells me its the differential internals slapping up and down, but im hoping its the center support bearing?
  • Rob
    • 8166
    diff bushing maybe?
    BEERTECH
    • Erick
      Official R3V Drifter
      • 11169
      I noticed my seatbelts were hanging and making clunking noises while I drove around after I took my rear seat out. :roll:
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
      • M-technik-3
        • 18946
        Could be a variety of things. Could be your upper shock mounts or Lower control arm bushings.
        • E30godz
          • 1524
          shock mounts fine, replaced with E46 cabrio mounts and reinforment plates.
          i inspected the CA bushings not long ago and they were fine, but i highly doubt this should even be considered as the noise is eminating from the rear of the transmission to the differential
          • M-technik-3
            • 18946
            That's funny where do you think they are located? Hmm between the two items you mentioned. But there are a few more items and sound can travel funny thru metal so it's not always where you think it is.
            Has the car been on a lift lately? Get it up and look for loose items, ie exhaust or exhaust shield. Could be Carrier Bearing in the drive shaft also.
            • Bill 84 318i
              • 1600
              Sounds like classic symptoms for the rear subframe bushings. I'd do everything back there (trailing arm bushings, rear subframe bushings, and diff bushing).
              • E30godz
                • 1524
                am i missing something? lower control arms are a front suspension component...unless you refer to as the "lower control arms" as the "rear trailing arms" as this is not an E36.
                • M-technik-3
                  • 18946
                  Yes I was refer to the rear trailing arms.
                  • mirror
                    • Apr 2004
                    • 34
                    I have the same problem, new absorber top mountings, new arms bushings , new diff bushing, new long sharf bla...bla.. :roll: sound come from the rear left
                    • E30godz
                      • 1524
                      i bet its probably the rear subframe bushings....do they have a tendency to squeek as they go bad too?
                      when im driving and the road is not ultra smooth pavement, but just like...regular asphalt, it squeeks a bit..but only under very tiny movments.
                      considering the last 30k miles have been pretty hard on the car and the many auto-x's ive attended, the possiblitiy of the bushings going bad is pretty high.
                      urethane or stock?
