help: cluster?
  • Majjic
    • Jan 2008
    • 150
    help: cluster?
    i was driving today and the cluster's mileage stopped counting,
    its stuck at 210,999 ?
    never had any problems before, what could be the reason>
    its a 91' 318is with a m50
    thanks
    - 88' E30 M3 -
    - MKV JETTA TDI -
  • Jordan325iC
    • Aug 2005
    • 1697
    Your odometer gear broke. Very common.
    You can either replace the odometer gear, replace the whole speedometer/odo assembly, or replace the whole cluster. None of these jobs are very hard.
    I think I actually have a working odometer/speedometer assembly with 202,XXX miles on it that you can have for $20 shipped. I'll have to check. PM me if you want it.
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
    • Drew325is
      • Oct 2004
      • 520
      ^+1
      ..and just a helpful hint to reduce the chances of it happening again...avoid resetting the trip meter while the car is moving.
      • txleadfoot
        • Apr 2006
        • 208
        211k miles is the limit. ;-)
        • Sean
          • 5793
          OMGWTFBBQ??!
          Mine is at 248,000! lolz :P
          - Sean Hayes
          • bignate948
            • Apr 2006
            • 542
            aw shit im gettin close
