Drain hose Q
  • nefarious7907
    • Jan 2005
    • 1170
    Drain hose Q
    The hose behind the drivers side front speaker, where does it attach too?
    Is it the sunroof drain? Let me guess this is going to require removal of the headliner.
    I found the reason my carpet has been soaked is not from a leaking heater hose but from the hose exiting about an inch short of where it should and it has caused a bit of cancer in my interior.
    http://www.cardomain.com/ride/657387
    Yep, that's a sunroof drain. If the cause is that the hose is too short, extend it so that the end is outside of the car. Beats having to remove the headliner.
    • nefarious7907
      • Jan 2005
      • 1170
      So just cut the hose and use a use like a heater hose coupler and add some more hose
      And I was getting to the point where I was like What the Fruck is going on, why is carpet wet?
