so im currently in the process of hiding the wiring for my sub/amp.. and i need to remove the part of the dash that houses the heat switches and fan and all that.. the lower peice.. can anyone help me out?
HELP. dash removal..?
i think most of that stuff stays in place when you pull the dash off. there are a few writeups that should inform you. -
what im really tryin to do is not take the entire dash off.. if its possible at all.. i just want that lower peice to come up so i can pull the sub wires under it through the center console to get into my trunk..
ill look around for some other write up..
thanksComment
Dude, I sent enough RCAs to run them properly, NOT under the center console.
Run them in the factory routes along the drivers side!Comment
It really isn't hard, the toughest part is getting the door sill off in one piece without breaking it.
LukeComment
its a bitch but if you try running down the console you will be replacing the rcas before you know it.Comment
