can I pull auto tranny and engine together?
  • T.Dot_E30
    • Mar 2004
    • 286
    or should I separate before??
  • e30s52
    • Oct 2007
    • 5235
    yes you can pull both at the same time
    www.gutenparts.com
    • ZiMMie
      • Jun 2004
      • 968
      Yea Trevor. u can, to make things easier pull the A/C compressor and the ps. Pump.
      Do it on a sunday, and ill help u out.
      www.stancefactory.com
      • T.Dot_E30
        • Mar 2004
        • 286
        Everything is off the engine, the ds is disconnected.
        ps pump and A/c cpmpressor disconnected. And the engine is ready to come out.
        I'm just afraid of my a/c condensor filled with r134.
        The engine will be out tomarrow. Give me a call if you wanna swing by.
        • txleadfoot
          • Apr 2006
          • 208
          i used a coat hanger wire to suspend the connected/charged a/c compressor away from harm.
            • 37833
            Might have to move the sway bar out of the way to get it out as one unit.
            Grover Beach, California
            BimmerHeads.com
