weird behavior
  • jw 325ic
    • Sep 2006
    • 1360
    weird behavior
    its on the wifeys 91. ok, so i replaced the engine temp sensor in the thermostat, and before the idle was surging from 400-900 rpms. now with the newer one(used) its going from 600-1000 and when the cars warm it'll sit all the way up at 1500. there arent any vacuum leaks ive already looked. i know i need to clean the ICV...
    also since ive replaced the sensor, when you push on the brakes hard, the check engine light will come on on the cluster. when you tap the gas, it turns off. it doesnt always happen, but it happens. i need these things fixed asap. thanks
