M50 Swap Question
    M50 Swap Question
    Anybody know if the 325ix brake booster will work?
    I know somebody mentioned it in the context of an M50 swap, but I want to know for sure.
    '91 318is
    I think, I am not sure, that the ix booster can be useed, but you have to have a remote resoir for hte bralke fluid.
    I am gonan use the '83 320i booster my self. I think that is the one that Zionsville sells for the swap.
    what trans are you going to use?
      I have been told it will. I have no idea what you are talking about remote resevior, it sits on the master cylinder which you can use an E30 one or one from the 3.5l engine for a nupgrade. The reason you use the smaller booster is clearance to the back of the engine.
      I got a booster from a 320i also and the MC from a 535. Does anyone know the length of the shaft on the E30 booster so I can trim mine down and rethread it before the swap begins?
      I am using the M3 tranny, It just means I need the E30 M3 driveshaft. You can stick with the E30 shaft if you use the regular M50 tranny.
      Im now E30less.
        Thanks for the responses guys.
        I'm going to be using the getrag 260.
        Where is the cheapest you guys have seen 320i boosters? The euro depot sells rebuilt ones for $220.
        By the way, I just drove Greg's (mtechnic3) e30m50 and the thing is beautiful. So much more low-end torque than an m20b25, and just all-around much smoother.
        '91 318is
          I found a used one that works off a friends old car. I will run that until I can afford a 02 one reubilt with the longer shaft.
          I do have another swap question. i have yet to work on an S50, where is the oil sump pickup for the S50? Do I need to jack the pickup from the M50 from the E34?
          Im now E30less.
            The oil pickup and pan are from the 525i (e34) be certian it has the m50 engine, the early e34s have the m20 I think and I believe that pan will not work.
            Autozone.com has them for 112.97 if you can find a core
            Be sure to shop around, Euro depot told me 180 a while back. Are you planning to buy the engine from them?
              The iX booster fits well, the only thing that you might have to do is grind flat some of the fins from the intake manifold.
              I'm running the stock iX fluid reservoir but it comes in contact with the throttle body boot which is why I'm probably going to a remote reservoir.
              One thing to keep in mind with the 320 / 2002 boosters is that some people complain about their lack of capacity affecting brake pedal feel.
                Oh, i have an engine. I also have the M50 E34 Oilpan and I can go back and get the pickup off the E34 engine. Do I need a new pump too or just the pickup?
                I would assume its the right one. They said the core came out of a 5 series and the date code is Mar 92. It was a DOHC motor. I tried to cross refrence the part number but hte only one I could find is the older short one.
                As soon as I locate someone with a parts tank I will srtip it off all the old oil and grit because there are shields covering the level sensor and below the crank. The core engine was missing the dipstick and tube so I still have to track that down but those will be cheap enough through the dealer if I have to.
                Im now E30less.
                  that's the right oil pan, but you're missing the oil level sensor on the bottom of it. You only need the oil pickup tube, but it's easier if you just get the pump/pickup combo from an e36. Remember to use some loctite (I used red) on the oil pump gear bolt, as it has a tendency to back out under extreme use.
                  I'd recommend the getrag 260 tranny, you can also keep your old diff and driveshaft :)
                  My brake booster cost me $20. Go to a damn real junkyard and pull one off of the endless supply of e21s
                  edit: my ix booster cost the same ..20
                    I have the sensor, its sitting on the bench out of the shot. i removed it to, hopefully, strip the pan as soon as I find someone with a parts tank.
                    Im now E30less.
                      Does the e36 m50 already have this sensor? I have the pan on delviery and already have my engine, I do not know where the oil level sensor is though on the e36 one
