bled the slave cyl and...
  • jw 325ic
    • Sep 2006
    • 1360
    now the clutch is falling to the floor....time for a new slave cyl?? the clutch was working fine before but now i bled the system and its stuck.
  • NC325iC
    • Mar 2004
    • 6565
    check it again in the morning, i know this sounds stupid but give it a shot
    • backtrail69
      • Jul 2005
      • 4471
      May need to power bleed it. I hate that fucking thing.
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • jw 325ic
        • Sep 2006
        • 1360
        Please explain how to power bleed. thanks
          • 37833
          Did you remove it from the trans and bleed it the right way? Many people don't know that it sits upside down when installed.
          Grover Beach, California
          BimmerHeads.com
          • jw 325ic
            • Sep 2006
            • 1360
            no haha. i have a shitty haynes manual and i went by that. whats the best way to bleed it and do you think this will fix the problem? ive replaced master cyl and bled the brakes, that was easy as hell, so i assumed this would be pretty straight forward.
            before i bled it, the clutch was fine, and the it seemed that the slave was just making noises. so i bled it, and now it just falls to the floor. like...i tap it with my foot and on its own just straight to the ground.
            • Madhatter
              • Oct 2004
              • 966
              sounds like a dead master cylinder if there is no resistance to the pedal and it just swings about.
              Just a little project im working on
              - http://www.lse30.com -
              • jw 325ic
                • Sep 2006
                • 1360
                when i press the brake pedal, the slave sinks down to the floor if that helps. i dunno, on my vert, when the slave went out, the pedal did the same thing. then when my master went out the clutch was fine but the brake pedal would fall to the floor... and this didnt happen til i bled the slave so its gotta be that imo...
                • jw 325ic
                  • Sep 2006
                  • 1360
                  been searching, sounds like it could be the master. should i just replace them both? the brake pedal works perfectly though...thats whats weird to me.
                  • backtrail69
                    • Jul 2005
                    • 4471
                    The clutch master is a different part than the brake master cylinder FYI. Only thing the two systems share is the res.
                    :: PNW Crew ::
                    • Madhatter
                      • Oct 2004
                      • 966
                      Loss of fluid at all? or is the pedal just doing weird things?
                      • jw 325ic
                        • Sep 2006
                        • 1360
                        only a little bit of fluid bled out, and in the brake fluid reservoir the fluid amount didnt really change...to the point that i didnt need to add any fluid. im clueless honestly. i dont want to spend all sorts of money getting a new clutch master and slave cyl either. i really want to figure out exactly which one it is if either at all...
                        • netcsk
                          • Apr 2004
                          • 1609
                          Try pulling the pedal back to the position it should be, removing the cap from the reservoir, and removing the slave cylinder from the transmission. Push the rod on the slave cylinder in slowly and release the rod slowly. Do the same a few more times. This reverse bleeds the system and has always worked for me when I had no pedal feel.
                          • tjts1
                            • May 2007
                            • 1851
                            The clutch slave cyl is upside down. When you tried to bleed it you put a bunch of air in it. The bleed screw has the be the highest point of the slave cyl in order to bleed it use a piece of hose attached to the bleed screw that snakes upward then back down to trap the air bubbles in the hose and not the slave cylinder. Otherwise use a power bleeder.
                            http://www.pelicanparts.com/BMW/tech...utch_Slave.htm
                            • scabzzzz
                              Estado de mierda de encargo
                              • 6871
                              Sounds like also you should have bench lubed the slave cylinder upon installation.
                              I just did my master and slave clutch cylinders last weekend and it took a lot of pumping and fluid spitting to get all the air out.
                              Also, the pedal will stick to the floor if it still has air in it. Have one person in the drivers seat pumping the pedal then hold it down. You, under the car, open the bleeder valve on the slave then close it. Pump 4-5 times and hold it to the floor etc. Repeat until the pedal feel is gone and you are pouring fluid from the bleeder valve.
                              So yeah, sounds like you didnt bleed all the way. Power bleeder would help but not necessary.
                              And take all of the advice above. Its legit.
