Hi guys...
After spending a few days in a yard I discovered that the e30ix booster is very similer to the merc benz. Even the part number is the same and only the last three digits are different. The e30ix booster part number is 34331161486 and the MercBenz is 34331161xxx. Sorry I dont know from which model of Merc Benz.
If you want to use the BMW brake master cylinder, you have to drill a bigger hole in it in order to fix it to the Merc booster. Othwerwise, you can use the Merc Benz brake master cylinder.
Also, you can use the brake booster from a Fiat Coupe which is about 1inch bigger in diameter than the Renault R19 booster but 3 times as long. In the Fiat Coupe booster, all the screw points are in the same position as in the BMW e30 booster, but the booster rod is a bit different and needs some small modification, which is not a big job.
The Renault R19 booster is about the same size as the Fiat Punto one, so the Fiat Punto is not the best booster for the E30M50 conversion.
In the next few days I will swap my R19 booster for a Fiat coupe booster for better braking, I hope.
Mirror.
Mirror.
