Thanks in advance for any response to this question.
We have had this issue on our car for the past 3 years and have not yet found the cause, or remedied it.
Under load the ignition coil will intermittently cut out and cause the car to stumble, costing precious seconds each lap! We have done numerous things to try and repair the issue, have also spent hours on the dyno trying to track this problem. Today I had a great idea about what it could be, and will try it tomorrow.
where r3v comes in.... basically I want to put together a check list of things to check and go over everything to make sure it is up to par. Anything from check the fuses to make sure the cat isn't clogged would be helpful for my purposes (even thou the car has no cat and only 8 fuses of which none have anything to do with the engine.)
