Hesitation
  • noid
    • 1537
    Hesitation
    Still trying to figure it out :o
    My car hesitates sometimes. When i press the gas between a tiny little bit or completly full throttle nothing happens. Doesn't happen all the time, its most apparent under half a tank of gas. When it hesitates the temp gauge goes ape-shit.
    So far i have replaced the following
    Wires, distro cap and rotor, ECU, afm, spark plugs, new fuel lines, filters - all to oem
    Wtf could this be? What is there left to check? ANY suggestions are appresiated. Iv been trying to figure this shit out since last january.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • ethirtydavid
    • Jan 2008
    • 2331
    Fuel pump solved my hesitation, definitely put it on your list of things to check/replace.
    • noid
      • 1537
      which pump? In or out of tank?
      • ethirtydavid
        • Jan 2008
        • 2331
        the fuel pump under the rear seat on pass side..
        • netcsk
          • Apr 2004
          • 1609
          noid, you have two pumps while david only has one. Either one of your pumps could be causing the hesitation. I'll pull your rear seat and remove the cover on the passengers side. Use a screwdriver, placed on the pump and your ear, to listen to see if the pump is running.
          • E30_fiend
            • Apr 2006
            • 7348
            Check your fuel pump relay, that wasn't on your list.
            Its either that or the fuel pump
            E30_Fiend
