Sway bar bushings
  • kroberts
    • 680
    Sway bar bushings
    My car has aftermarket sway bars on it. The PO installed them, I dont know what brand they are. The front bushings are getting old, the urethane is getting that cloudy look, they are starting to break down. I'm going to order replacements but do I need to know what brand the bars are? Are all aftermarket 22mm sway bar bushings pretty much the same?
    Thanks
  • ddavidv
    • 344
    What color are the bars?
    Suspension Techniques are yellow, and IE bars are blue.
    Bushings should be pretty much universal though provided you get the ID right.
    • redhatpat
      • Aug 2005
      • 656
      Unless they're shaped differently, size is all that matters.
      • kroberts
        • 680
        Thanks fellas. I did a little surfing today. I'm guessing mine are from Suspension Techniques based on the color of the bars.
