So the other morning i go out to my car and I realized my antenna was up, confused, I tried to turn the car onto the on position and turn the radio on and off, but I couldn't even hear the antenna motor even attempting to pull it down or anything. Also after that I tried to put my windows down(without the key in the ignition, because it used to work if i just had one door open) and it wouldn't work unless I had the key turned to On.
What do you suspect is the culprit? a fuse?
