Help
  • ban1
    • Nov 2007
    • 235
    Help
    I was driven to work last night and out of nowhere my car quits gettin gas. I think it is the fuel pump ,but it could be the fuel filter. I am goning to go check the fuses now. But this is what happened. I was driving and it was running fine. Then i went up this hill and the tach droped RPMs. So i pulled it in this lot on the side of the road. I tried to start it up and it was getting fire. So that leads me to beleive that its the fuel pump. The front fuel pump was working I flelt and heard it viberating. Just let me know some thing like weres the fuel filter. Also tell me what you think it is.
    Sorry if I spelled some things wrong and made it hard to read. I have just been up since 9 a.m. yesterday. Cause i work graveyard at the fablous Perkins in Danridge. And if your driven thourgh Danridge don't eat there it nasty unless its graveyard or moring shift. So form 1 a.m. - 3 p.m.. Or if there is a black man named Lawernce working his damn good. But tell you all about my work was pointless. But waitress are hot it's like a tone down Hooters. Pointless again I know. I need to go to bed.
  • ban1
    • Nov 2007
    • 235
    bump
    • ban1
      • Nov 2007
      • 235
      bump
        The fuel filter is above the high pressure pump just in front of the left rear wheel. A clogged fuel filter is a possibility, by so is a failure of either of the fuel pumps or the FPR. Replace the filter and then run the pressure and delivery tests documented in the Bentley.
        • ban1
          • Nov 2007
          • 235
          its not the filter it was good. It had gas in all the lines. I took off the main feed line and it leaked a lot of gas. the fuel filter i could blow through.
          My friend said it was smoking yesterday. He waited till today to tell me.
          • ban1
            • Nov 2007
            • 235
            I found out what it. It was the timing belt. I am fixing it some time next week. It might of jumped timing. So whats the degrees its set on.
            • DCColegrove
              • 2748
              ...That's not good.
              When the timming belt breaks it bends the valves and often breaks shit too.
              • xLibelle
                • Aug 2004
                • 2673
                give it up, if youre asking a question like this, you probably need to hand the tools to someone else
