Please help me with my list..
    well my car is kind of crapping out on me. Its misfiring occasionally when im on the highway like its not getting fuel or spark. i need to take it to a shop since i dont have time or enough knowledge to figure this one out...
    Ive also been putting off my suspension and some other stuff so i figure i mine as well order that from bma tmrw and get it all done at the same time. I need help with a list, car has 140,000 miles... so keep that in mind.
    heres what i have so far that i put together in 5 min. anything thats reasonable you can add will be a help..
    struts-
    front strut mounts-
    rear shock mounts-
    front rotors-
    front pads-
    rear pads-
    pad sensor-
    rear wheel bearings-
    tie rods-
    tie rod ends? do they come together
    02 sensor
    bushings...
    should i get a whole control arm that has them pressed? i dont think mine are bent or anything or just the bushing seperate..
    Front Sway Bar Bushings-
    Trailing Arm Bushings-
    Subframe Bushings-
    Rear Sway Bar Bushings-
    Differential Mount Bushing-
    I know this is a pain for you but im in a jam and pressed on time. Seriously thank you for whoever has input, i really appreciate it. I'm sure ive missed some obvious things and ill start searching and edit later tonight.. Dan-
