stop test not working
  • Schneider325
    • May 2004
    • 3818
    What could be the problem if the stomp test results in nothing. I've turned the key to the on position and hit the gas 5 full times. Every time nothing happens.
    Thoughts?
    thanks
    Jon
    That failure will probably be caused by a problem with the TPS. The DME has to see five iterations of alternating idle and WOT signals from the TPS. The TPS could be bad or the throttle cable and/or idle stop could be mis-adjusted.
    • Schneider325
      • May 2004
      • 3818
      What does TPS stand for? I tried looking it up in the bently and came up with nothing.
      • kamotors
        • Nov 2007
        • 7102
        throttle position sensor
        7speedshop.com
        • Schneider325
          • May 2004
          • 3818
          I couldn't find any info on that in the Bently. What term should I be looking up?
          • James Crivellone
            Head Janitor
            • 6301
            throttle position switch
