Wtf!!!!!
    Wtf!!!!!
    ok so i connected everything. repaced all gears checked that the wire to the diff is connected...still no speedo.
    is there anything else to do
    temp guage works, fuel gauge works, tach works, si lights work. fog light work. WTF? :hitler::hitler::hitler:
    Operation S/C E39M5.:woowoo:
    Could be just a dead speedometer. I've heard of it happening, but it could also be the speed "sensor" in the diff gone bad..........
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
      Pull the speed sensor out of the back of the diff. Look at the two wires that go into it, are they corroded also check the pins inside the sensor. If they are back you can cut it off and crimp two simple connectors on the ends of the wires and plug it back in.
        i've had a speedo die.
          ok thanks guys im on my way to the junk yard. im gonna pull as many speed sensors in the back of diffs that i can find.
          reason being. (ima stupid noob) and one the speed sensor wires were corroded the one on the right hand side. so i just unplugged them booth and yea did the dirty work. so im on my way to pull a part. ill post again in . roughly 2 hours on my lemonade and burger break.
            ok problem fixed. thanks alot guys! whoo now i can see when i should watch out for that speed ticket!
