new issue....
  • der affe
    Technical
    • Dec 2005
    • 8452
    new issue....
    OK so have the new cat on the car and they fixed the shitty install job
    i haven't had a cat on the car for about 2 years since the last time i went through emissions.
    the new problem is the car pings until around 2000 rpm when accelerating in 1st 2nd and 3rd gears. it has never done this before. i always run 91 (we don't have 92 or higher in AZ). WTF?
    can i retard the initial timing in the dist? to help this out until i can make another cat bypass section?
    any suggestions?
    thanks,
    Greg
  • ethree
    • Aug 2007
    • 1213
    Why would the cat cause detonation?
    • der affe
      Technical
      • Dec 2005
      • 8452
      i don't really know....more back pressure????? although that really doesn't make any sense, E30's run with them all the time. maybe my cat by pass was loud enough that i couldn't hear it before. i am open to suggestions though.
      • ethree
        • Aug 2007
        • 1213
        I had a bad tank of gas a while ago which made my car detonate a bit under load so I used some of that octane booster crap which helped quite a bit until I put the next tank of my usual chevron 91. It's a thought.
        I was more just curious as to what led you to believe the cat was related? Anything other than timing?
        • der affe
          Technical
          • Dec 2005
          • 8452
          that is the only thing i have changed, the mileage has dropped too
          • der affe
            Technical
            • Dec 2005
            • 8452
            bump, anyone?
              A stock M20B25 won't ping with 87octane gas. Only if the engine has a chip should you need higher than 87. Has a chip been installed?
              • der affe
                Technical
                • Dec 2005
                • 8452
                here's a quick list of the specs. rember it is a 2.7 STROKER , not a 2.7 ETA
                from my understanding the 325I has higher static compression so you need to run the 91 octane.
                if i could i would run the lower octain for the burn travel and lower gas $$$
                • ethree
                  • Aug 2007
                  • 1213
                  Mine is a chipped m20b27 I should have stated that in my earlier post.
                  Did you do a full rebuild when you built your stroker?
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    oooopppps the link in the earlier post didn't take.....now it makes more sense.
                    i bought it with the motor already installed, but he showed me recepts for a full rebuild
