I'm in need of you guys guidance on this. Ok first off before anyone says search I did already and I still can not figure this one out. I tried troubleshooting all the problems that lead to the faulty fuel gauge. First I checked the fuel leveler unit and replace it with a new one. No movement on the needle after this was done. Second I read that it could possibly be a bad SI board. So i went to the yard and got this:
2 VDO Si board (90 325i)
(91 318)
2 VDO fuel gauge (Same as above)
First off mine cluster is a MOTOMETER, but i read that VDO should be ok. Right?
Well I tried swaping only the 325 vdo si board since it looked more compatible to the moto meter board today. Also tried swapping the 2 different fuel gauge. Turned on the car and still nothing. I'm stuck right now and can't figure wtf is going on. What should I do guys? Should I start looking for motometer components? TIA!
(91 318)
