Injectors not injecting!!!
  • iamsam
    • Jun 2008
    • 176
    We were trying to get my brother-in-law's 1987 325e (that he got for free) to run today, and we put in a new fuel pump (cuz it needed one). The car has not been started for several years, and it is quite the restoration job.
    Ok, here is the problem:
    The car easily turns over, and it runs, but only if i am spraying starter fluid straight into the intake, but otherwise dies, i.e. there is no fuel coming out of the injectors. There IS fuel pressure in the fuel line going into the end of the fuel rail on the firewall side, cuz we pulled it off and fuel squirted out, and there is fuel in the fuel rail, because we pulled off the fuel pressure regulator and fuel squirted out of the rail, but the fuel line coming out of the regulator was dry, i.e., no fuel going through the regulator.
    What can be wrong???? please help!!!!!
    -Sam
    btw here are some pics of the car i am talking about. (my bro-in-law got it for free)
  • JAM
    • Feb 2007
    • 524
    clogged injectors? though i doubt they would all be clogged liek that....
    did you pull the hose off before or after the fuel pressure regulator? it could be clogged/not working
    Originally posted by Mr Watsonsilver
    driving boards?
    • iamsam
      • Jun 2008
      • 176
      I doubt all six injectors are all clogged at once. I am thinking it has to be something else that controls the injectors.
      i pulled the fuel pressure regulator (the little black cylinder thing) off of the fuel rail, and fuel squirted out of the rail. I also took the rubber hose off of the other end of the fuel pressure regulator, and it was bone dry. So no fuel going through the regulator. But i can't see how that can be the problem. Or can it??
      • JAM
        • Feb 2007
        • 524
        gee idk if there is no fuel going through the regulator i guess that wouldnt be a problem at all
        WAT
        driving boards?
        • iamsam
          • Jun 2008
          • 176
          WAT
          yeah that's what i was thinking..... i was hoping someone would have had an experience like this and would be able to tell me right away what it was... i even downloaded a 1300 page E30 repair manual in pdf format, but no luck. Thank you anyway, i appreciate any input i can get.
          • StereoInstaller1
            GAS
            • 22679
            Hey there...IMO, the first thing to check AFTER checking fuel pressure is the timing pulse from the sensors on your bellhousing. No pulse = no squirt.
            Go kick its ass.
            Luke
            Closing SOON!
            Thanks for 10 years of fun!
            • iamsam
              • Jun 2008
              • 176
              Go kick its ass.
              Luke
              ah! ok, there is fuel pressure, i know because i detached the fuel line on the firewall side and it sprayed everywhere, and about that timing pulse, how do i check it, and where is it more specifically?
              Thank you so much for your help!!:up:
                That says essentially nothing about the fuel system. The only way to tell if it is working correctly is to check the pressure at the inlet to the fuel rail. The fact that you didn't see fuel flowing from the outlet of the FPR means that there isn't sufficient pressure or that the FPR is plugged. The former would explain why the engine won't run.
                Get a gauge and see what the inlet pressure is.
                • iamsam
                  • Jun 2008
                  • 176
                  Hmmm.... because we did replace the fuel pump with something i got from ebay for $75. Is it possible that the fuel pump is not pumping hard enough to make enough pressure in the fuel rail?
                  • rs4pro3
                    • 5808
                    step 1- Check fuel rail pressure on the feed line going into the regulator, pull the fuel pump relay and jumper pins 30 to 87 to make the pump run with the car off. Pressure should be between 35.6 and 37 psi
                    And report back your pressure here
                    Step 2- if pressure checks out, check for 12-volts at the injectors them selves on the red/white wire
                    Step 3 if all that still checks out, then you'll want to test the speed and reference sensors.
                    I'd recommend picking up a bently or haynes manual as they cover all these tests.
                    85 325e 2.7 ITB'd stroker
                    • iamsam
                      • Jun 2008
                      • 176
                      thank you!!! i will get on that!
                        It sounds like the engine has spark and that the fuel pump is running when cranking. In which case timing reference data is present at the DME.
                        I don't know whether this car's engine harness has the C191 connector or not, but if that connector is present a fault in it will take out the injectors.
                        • iamsam
                          • Jun 2008
                          • 176
                          So what you guys are saying is that either:
                          1. The fuel pump is not adequate to make enough pressure in the fuel rail
                          2. Electrical problem in some wiring harness
                          is that right?
                          • rs4pro3
                            • 5808
                            Ya you either have some sort of fuel issue, Pump could be fine but the regulator could be bad. Or it could be an electrical issue. And no his car does not have the c191 plug as that is just on the 325i from 88 up.
                            • iamsam
                              • Jun 2008
                              • 176
                              ok so you say that the FPR could be bad? hmm i have had someone tell me that before. But what i don't understand is how a bad FPR can cause fuel not to go through the injectors.
