New shake
    New shake
    Just started. The car shakes at 40 and all the way up to 60 then starts to stop but its is still there a little. I checked the flex joint it looks fine. wheels are all on tight. i think i know what it is but I thought I would ask before I tear in to it.
    Update.
    It is coming from under the car more than from the wheels. and it goes away when i push in the clutch
    http://raceskids.com/
    Could be an out of balance wheel, or even a bent wheel.
      maybe.
        If the vibration goes away when the clutch is disengaged, I'd suspect binding u-joints in the drive shaft, probably coupled with a failed CSB. If that's the cause the vibration should be worse when the drive train is subjected to high torque loads, like when briskly acellerating from a stop or up a hill.
          That is what I was afraid of. Any one have a good drive line local?
            Vancouver Driveline of Hwy 99
              I will check it out. any good used ones out there?
                meh if your gonna do it, do it right. these guys are the shiz:
                  have you checked your flux capacitor lately?
