Maplight mirror in a 318is
  • mikey
    • Mar 2004
    • 208
    Where should I get the power for the maplight r/v mirror? Anyone done this before? Is it possible to wire it to the SRS panel?
    TIA
    -Mikey
    My transaction feedback thread(s):
    http://www.r3vlimited.com/board/showthread.php?t=292029 :up:
    http://www.r3vlimited.com/board/showthread.php?t=329392 :up:
  • Ryan Stewart
    I Love Miatas
    • 8978
    I used the check control.
    When installing the mirror precompress the springs with a pair of vice grips. Then slide a couple zip ties to hold the pins partially compressed. Then after installing it slide them back out.
    Im now E30less.
    • hamann318is
      • 3382
      Check control, something the 318is is lacking...
      I think that there is a different color wire. Search google for Franz 318is, his site had the different wire color for the SRS panel.
      The BMW 318 is back. With a vengeance.
      • James Crivellone
        Head Janitor
        • 6305
        gotta run a seperate power line down the A Piller, we did it on my friends car
        • Bryson
          • 1490
          you can run a power wire down the a-pillar to the factory plug (which does exist in the 318) however, in mine, I had converted to an electric sunroof also so I tapped into that power (ign). Try to source the harness for the maplight mirror from a junkyard car, or, god forbid, the dealer. If you feel so electrically inclined, or you want the maplights to work with the headlights off, it's a piece of cake to wire them however you want. Be careful as each bulb is ~$15 and you don't want them left on.
          For those with maplight mirrors, you can upgrade to a 5w higher bulb from I think an e23
