blinkers do not work, and hazard button buzzes only SOMETIMES
  • JoeyJoeJ0
    • Sep 2006
    • 223
    Title explains itself. I've replaced the turn signal relay but that didnt cure anything. It was a used one but i am positive it worked before i put it in. The hazard button only buzzes sometimes, and sometimes the hazards work fine. but my blinkers ALWAYS dont work. any ideas?
  • Court M3
    • Jan 2004
    • 6713
    change out the hazard switch
    Continuous For Sale Thread
    323i s50
    • mattdk318i
      • Jun 2006
      • 3953
      everytime, The contacts burn out. And the hazard HAS to be good for your blinkers to work
      • JoeyJoeJ0
        • Sep 2006
        • 223
        when you say hazard switch, do you mean the actual button? or is there a relay or something.
        • george graves
          • 20003
          ^The big old red button.
          Originally posted by Matt-B
          • JoeyJoeJ0
            • Sep 2006
            • 223
            hmm wierd cause i did swap it with one that i know worked perfectly... should i check contacts in there or something? will contact cleaner do anything? and the problem is so inconsistant...
            • JoeyJoeJ0
              • Sep 2006
              • 223
              just swapped the hazard button and the blinkers still dont work. hazards are working right now as well. could the relay for the blinker stalk be bad even though i replaced it with a working one? or is the blinker stalk done? the solder points looked fine when i took the column apart and looked at it, but could i be wrong? thanks for the input so far guys i appreciate it.
              • mattdk318i
                • Jun 2006
                • 3953
                yea, that would probably be the next logical step, Did you check the ground on the stalk?
                • JoeyJoeJ0
                  • Sep 2006
                  • 223
                  actually no, where is that located?
                  • Gray S.
                    • Jan 2008
                    • 173
                    Im having the same problem, except that my blinkers and hazards work when its real hot outside sometimes. I was going to just replace the turn signal stalk, but I'm not sure why it being bad would effect the Hazard Button?
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      The ground. Follow it from the relay on the stock. You'll find it. And I would say just buy a new relay for the stalk. No need to swap in a used part when the relay is cheap. If none of what people are saying works, replace the stalk.
                      So check the hazard switch terminals, change the relay on the stalk, and last thing would be to change the stalk. If that doesn't work then you have an electrical problem.
                      Taylor
