Oil filter housing is leaking
  • Jand3rson
    • 37587
    When I started my car today to check a few things, I noticed a fairly steady drip coming from under the car. I found it to be oil, and upon further inspection,
    discovered that it was leaking out of the bottom of the oil filter housing, shown here:
    I think I still have another one on the block from my parts car. Has this ever happened to anyone else? Why would it be leaking from there?
    I can't see it well enough to see if it's cracked or not, but I doubt it. I guess I can swap the other one over. Hell, I just did the oil pan.
    Also, do I have to drain all the oil to change the housing, or will most of it be in the oil pan?
  • rs4pro3
    • 5808
    There is a valve there that is known to fail sometimes cuasing links. I think it bypasses the oil cooled untill the car warms up. I saw mention of it on Roadfly somewhere about fixing it I'll see if I find the link.
    85 325e 2.7 ITB'd stroker
    • rs4pro3
      • 5808
      Here you go http://e30.bmwdiy.info/oil-leak/
      • nitro325is
        • 495
        that is the most annoying leak.I just did mine last week after tiring of it leaking all over my new rack and arm.That link is helpful.Definitely use a C clamp.Didnt remove the filter though.Also the new snap ring is such a pain to get in.
        • Jand3rson
          • 37587
          Awesome, that is EXACTLY what is happeneing. You guys rock.
          About how long did it take? It looks pretty simple.
            • 37833
            Better take it to the dealer ;) ;)
            Grover Beach, California
            BimmerHeads.com
            • Jand3rson
              • 37587
              Yeah, I don't know if I can handle that one... :D
              • nitro325is
                • 495
                Removal=2 min
                Install=about 5 min cuz I only had short needle nose that the ring would slip out of. long ones should make it much easier.
                • Jand3rson
                  • 37587
                  Removal=2 min
                  • AdamF 88iS
                    • 2051
                    Very very common leak. There should be repair kits avalibe from most parts places with a new seal, cap, and circlip.
                    Adam Fogg- '88 M3
                    Common sense- It's the new 'gifted'
                    • Kavkazia
                      • 394
                      Better to do in morning, cold, remove oil filter, lines, have rag ready for little leak, undo the big bolt, don't remember the size, and you have the housing in hands!
                      Make sure lines are high facing up, because you don't want to get oil on your face, :).
                      95' M3.
                      90' 325i Turboed.
                      87' 325eS Fixed.
                      • Jand3rson
                        • 37587
                        Yeah, I think I'm going to remove the housing in order to replace the parts. It will be SO much easier to do it that way, there is no room for tools in there.
                        • AdamF 88iS
                          • 2051
                          If you take the housing off you should replace the big O ring behind it and the small fat O ring that goes on the bolt that holds the housing to the block.
                          Adam Fogg- '88 M3
                          • Jand3rson
                            • 37587
                            I just ordered the kit from BavAuto, and added those two o-rings to my order.
                            • Jand3rson
                              • 37587
                              The parts to fix it have not arrived yet, and my wife has to take the car out of town this weekend.
                              Will it be ok to drive as long as she keeps close tabs on the oil level?
                              *EDIT* The parts just arrived. Looks like I'm doing some early-morning wrenchin' tomorrow.
