problem is the windows stopped working. i checked fuse #16 and it is good, but i have no voltage there. i traced the wire (white with brown stripe) to inside the cabin. does this fuse get its power directly from the battery or is there a relay or something? i jumped it with a jumper wire under the dash and the window switches lit up, and the windows went up and down. i remember a post about a wire on the starter being for the windows, i have a m50 so is there a wire in the car side of the plug that is for this? the chassis is a 89 325is.
problem with power windows, help please
Originally posted by mentaleeilli have a m50 in my car, where could that wire be now?? does it go to the car harness into the fuse box? if so what color is it?
i'm kinda in the same boat right now, i just installed two new front speakers and deck, everthing was paying nicly, cruising down the road, got hot, so i went for the windows, *SHIT!* they don;t work lol.. i looked in fuse box, and number 16 fuse is busted, ok great easy fix i thought, well, i replaced the fuse,,, and still nothing, that fuse is still in tact, what else could it be?! i could not find a (white with brown stripe) wire behind the speaker panel or behind the deck, i have a 1987 325is chasis,,, any idea?</img>
Schnitzel Not Rice....
crraaap. unloader relay wtf is that, heres the deal,, i got the deck when i quit best buy, i let them instal it couple months back, i took a look at everything they had done the other day, they were running the left f and r speakers off the postive front let speaker output, and the f and r left speaks fromt he FL speaker out put, all the bmw wires confused the f* out of me, so i just ran new wires (:)) i didn;t mess with any of the power wires they had hooked up (the power, constant, rem, grnd ect) just the speaker wires,,
i installed the front right speaker with no probs, went to work with widows down
came home, woek up next day, then did the front right speaker, speakers sound great, thats when windows stopped working... so i'm guessingi mess a wires up behind the speaker panel (?) i saw there is a white/ brn stripe wire coming fron fuse, but then what color does it turn into at the doors?</img>
