help with an new air intake?
  • diablo98110
    • Jun 2004
    • 24
    Im a bit of a newbie at working on my own car so bear with me... I just installed a JC chip for my 87 325i Cabrio, took it for a test drive and it ran fine for several miles. When i got back home i swapped out the stock air box for the filter kit from Turner Motorsports. got the car about 3 blocks down the road and it started cutting out so limped back home where the car finally died, and now will not run unless the throttle is most of the way down. It smells like it is flooded (can that happen with fuel injection?) and runs roughly at lower RPM's.
    Ive checked all the connections etc and even put an extra gallon of gas in it but the symptoms have not changed. I have not tried the old air box again and was hoping to avoid doing the work twice. so if any body has any ideas i'd greatly appreciate them :)
    Thanks
    Damian
  • e30Matt
    • 5077
    Did you reconnect everything?
    • bwanac
      • 3354
      What was involved in this kit from TMS?
      • Jordan
        • 12913
        Did you plug the AFM back in?
        https://mtechniqueabs.com/
        • NC325iC
          • Mar 2004
          • 6565
          if you unplug the afm it should be rough at high rpms not low rpms
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Oh no, it'll be fucked up all over the place. I pulled that one once.
            Jordan is right, check the AFM.
            • e30Matt
              • 5077
              Yep, go crank your car up, unplug the AFM and blip the throttle once or twice. Weird shit will happen.
              • spud814
                • 287
                yup, check the afm plug.
                • diablo98110
                  • Jun 2004
                  • 24
                  doh!
                  well i figured it out.. the flap inside the afm was stuck open.... so i wiggled it about 20 times and works smooth as ever now, runs great, building a cold air box this weekend so i wont have LESS hp from the stop light
                  thanks for the replies
                  • Skafrog
                    • 1732
                    Re: doh!
                    At least you know that your losing HP right now :-)
                    NASA MidSouth TT Director / GTS2 #018
                    Mods: Coastal PS Fluid, 10w40 Oil
                    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
