Tachometer pooped out. . .
  • deathtomine
    • Jun 2008
    • 206
    I just finished putting my transmission and clutch assembly back into my 318i and now my tachometer won't read correctly.
    When I started up it it was working then once in motion it quit.
    I also took my cluster out and painted my needles. could I have knocked something loose?
    I researched around onr3v but couldn't find anything close only stuff with the batteries on the si board.
    does anyone know of a solution to this problem?
  • EN318isPDX
    • Oct 2007
    • 4373
    Check the wiring behind the gauges. Also check for pinched wires around the tranny.
    • deathtomine
      • Jun 2008
      • 206
      Thanks I will check that.
      I went for a ride earlier and it did the same thing it worked in the beginning then it quit.
      • ADEN
        • 620
        Blown fuse. Check check
