Hitting a brick wall...
  • e30pwr
    • Oct 2007
    • 642
    Glad you got it figured out.
    • ///M42 sport
      • 3952
      whats a tps
      • VacMan
        • Apr 2007
        • 2405
        Originally posted by ///M42 sport
        whats a tps
        Throttle Position Sensor.
        • ///M42 sport
          • 3952
          How to do you check it? I'm having similar issues now
          • kamotors
            • Nov 2007
            • 7102
            yes i would also like to know some more on how to tell if the TPS is adjusted right and if it works.
            my car was idling at 1000+rpms and i had recently worked with my throttle so i checked there first and noticed that the TPS had slid to a different postion than before, i moved it to the "same" postion that i remembered it at but i'm not 100% sure its back to where it used to be. car drives fine now but i want to know how to double check. should it make a click or something at WOT, what i could check for?
            7speedshop.com
            • Adrian_Visser
              • Jun 2006
              • 2823
              basically the idle switch should make when the throttle butterfly is closed. just rotate the tps until it clicks right when the throttle butterfly is fully closed or a touch before. the WOT switch doesn't click as loud as the idle one. the idle switch is a microswitch and the top end one is just a wafer switch easy enough to test it with a DMM the centre contact on the tps connector is ground the sides are for the idle and WOT.
              '89 Alpine S52 with goodies
