Confused
  • MonthOLDpickle
    • May 2004
    • 107
    Confused
    Well I did the 5 speed swap. Now my temp guage gets a little hot. Its almost 90 during the day. But its gets 2 mm past half and when driving it a tab bit hard it gets closer to 3/4. Whats happening? I checked the coolant?
    edit:
    Now it does this even at the middle of the night? Its only 70 degrees out? Maybe a coolent flush would help? Also sometimes the car gases by itself. I check the lines but they re clear of junk and stuff. I look at the gas pedal and its not attached??
  • kencopperwheat
    King of Kegstands
    • 14396
    If it's 90 outside, that's fine.
    Originally posted by Gruelius
    • Jordan
      • 12913
      Wish I had that problem.
      Even when it was 105ยบ the other day I couldnt get it to creep past dead smack between 1/4 and 1/2
      https://mtechniqueabs.com/
      • Skafrog
        • 1732
        and that my freinds is the difference between thermostats.
        NASA MidSouth TT Director / GTS2 #018
        Mods: Coastal PS Fluid, 10w40 Oil
        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
        • Jordan
          • 12913
          I need to fix it... because my heater isnt even remotely warm. At night/early morning when its cold enough to want heat.. it wont even hit 1/4 lol.
          • TimmyBigHands
            • 260
            It's between 110-115F out everyday here, and mine only hits 1/4. Maybe a tad higher at a long light.
            • DarkWing6
              • Apr 2004
              • 7144
              It was 90-95 where I was at last weekend and mine only reached half when I pushed it a bit.
              • hamann318is
                • 3382
                Mine's usually a bit below 1/2, and that's been the same since I've had it. I got it in May, so the weather has been pretty much the same.
                The BMW 318 is back. With a vengeance.
